Brief Description: Cleaning, abrading and alodining.
I dimpled the wing walk doubler. Then I cleaned, abraded and alodined the wing walk doubler, leading edge to fuel tank joint plate, upper and lower inboard and outboard right wing skins as well as the leading edge skin and fuel tank attach Z brackets. Image 1 shows the skins, doubler, joint plate and Z brackets drying after alodining. The white objects on the table are the Henkel alodine applicators.
